Diplomat Dishwasher Pump
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat Dishwasher Pump
  • #27135
    skyliner
    😳 Bit embarrasing actually. Sometime ago in the mists of time, I was looking for a new pump for a Diplomat Dishwasher Model ADP8322. You responded very well but at the critical moment, I had to abort the situation. Sorry!
    However, I am now back from my wanderings and am prepared to really go for it.
    Can you please let me know if you can supply the replacement part. I understood originally that the part you had then was a very much more robust item – that’s the one I am looking for unless there is an even better one.
    If you can let me have details of purchase, I will respond quickly with the order. Would also be handy if you could also put me in touch with a fitter in the Peterboruogh area.
    Once again, apologies for having to let the first effort fall over.
    #212738
    Re: Diplomat Dishwasher Pump
    I think that this was what you were looking for:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159
    Nelly21
    Circulation Pump
    I have the Diplomat ADP8322 and there is no water presssure being generated by the pump. I think it’s a bearing’s fault, the magnetic armature sounds like it’s floping around inside the motor casing, causing noise and slow running operation. (As per this sites diagnosis).
    But Could you answer a question regarding this big Askoll pump motor.
    When spliting the front impellor houseing and the magnetic armature from the rear winding assembly, is there meant to be water in the armature section?
    And can you just purchase the front section?(impellor, housing and magnetic armature)
    Or do you have to buy the complete pump??
    Nelly21
    #212740
    Armature runs wet, and yes, there are no parts – new pump time.
    Nelly21
    Cheers,
    Thanks for your quick reply Penguin45, I’ll get a new pump orderd up tomorrow.
    Best Regards,
    Nelly 21.
    P.S
    Very inpressed with this site, will defo use it again. But hopfully not in the near future 😀
