Re: Diplomat Dishwaster ADP8332
There is a possibility of overfoaming having taken place. This would generate an F8 error. As a result of overfoaming the base may well be flooded and if the float switch is fitted to your machine this would generate the F2 error.
You’ll need to unplug it from the mains and take the machine out, put some towels at the back corners and tilt it back a little.
If I’ve got it right there should be some water drains out onto the towels.
Once you’ve done this test it by plugging it back in and holding the start button to reset it. Set your wash programe and hopefully it should now work.
If it still doesn’t work it’ll be engineer time and there will be no problem with the engineers on here carrying out the work.
Hope this helps.
DP
