Diplomat Dishwater – Light on – Code needed
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat Dishwater – Light on – Code needed
  • #7129
    deanacrooks
    My brother has a diplomat dishwasher – but the buttons on the left hand side where you set the program, one stays permantly on, one flashes and as result the dishwasher is jammed. and has been out of use for months
    A plumber has advised us it needs a release code to reset the programming.
    I have just found your fanstastic website and really hope someone can advise at all?
    Charges are £70 call out before anything is done we which feel is extreme as you can buy a new one for not much more than that!
    #121514
    Dave_Conway
    Re: Diplomat Dishwater – Light on – Code needed
    If you can post the model number and which lights are staying on and which are flashing we can advise further.
    A new dishwasher of this type, fully integrated etc would cost in excess of £400 to replace by the way, plus the cost of installation 😉
    #121515
    deanacrooks
    Details as follows:
    Model Number :ADP8242
    Light on Soak
    Flashing on Super
    #121516
    Dave_Conway
    That’s indicating that the dishwasher has a leak and the aquastop safety device has been activated.
    No reset for this one as the leak will need to be identified and rectified before doing anything else.
    There may be water in the base so I would suggest it is disconnected from the power and an engineer attends to repair it for you.
    The £70 call out you mention will almost certainly include some labour time, quite often enough to carry out the repair.
    #121517
    deanacrooks
    Many thanks for your help on this – much appreciated!
