Hello 😀 I have a Diplomat ADP8332 which is coming up with the FA fault code. 🙁 First how do I reset it, secondly if it comes up again what do you think the fault may be.
Hello thanks for that 🙂 , I presume that there is not a reset procedure (I have found comments on web about switch off, then on, press prog. button 4 times, shut door, and it clears its problem). Do I therefore require an engineer 😥
