diplomat double oven
  • #50786
    bandit2510
    Need help on this oven cant find any info on it anywhere,when using the grill it works fine for 10 mins approx, then the for whole thing goes dead and unable to use any functions for 1/2 hr. i.e when cooled down. It did show an error code on display briefly think ed13 may have been eb13 but i cannot find any fault codes for this appliance. This is a typical howdens cheapo double oven. I have replaced cooling fan as that was very noisy. Any help with fault codes would be appriciated.
    #305993
    bandit2510
    Re: diplomat double oven
    MODEL ADP 4540 SORRY….. :rolls:
    #305994
    bandit2510
    Re: diplomat adp4540
    Anybody…………..fault codes or previous knowlege of this machine.
    #305995
    Lawrence
    Is there a toc anywhere either a small two tag or a larger wire wound resisitor type .
    Also I assume you have done a temp test to eliminate the thermostat .
