Diplomat Double Oven fault
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat Double Oven fault
  • #92118
    Ian 1969
    Hi all
    I have the above 720eA ADP4540. Main oven works fine with no probs. Grill only works on full heat and top oven doesn’t work at all. Any ideas as i’m confused between dodgy thermostats, elements and switches 🙁
    Have just noticed that the small light to indicate correct temp of the top oven does not illuminate?? Could this indicate the prob?
    #450332
    Re: Diplomat Double Oven fault
    Yes, possibly thermostat.
    Ian 1969
    Thanks. I’ll get one on order and let you know the outcome.
