Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › diplomat dw,hja8630
- This topic has 11 replies, 5 voices, and was last updated 15 years, 8 months ago by
adv.
July 28, 2010 at 8:23 pm #56153
adv
Participantno this is a beko. customer phoned sayin fuse had blown she changed it an blew again.no rcd on circuit old type fuse box. i go up have good look. around cant see anything bad. change fuse and away it goes. runs drains but no heat.getin power to heater.didnt have meter with me,and you all no aint got a megger. yet 😆 heater dont look badly damaged. and appliance only 2 year old.am thinkin heater but if thats the case would it take out the 13 amp fuse? help lads 😆
July 29, 2010 at 7:16 am #326400pup
ParticipantRe: diplomat dw,hja8630
well only to do is disconnect heater ? 😆
July 29, 2010 at 8:35 am #326401adv
but didnt think a heater would take out a 13 amp fuse.it doesnt look damaged atall ?
July 29, 2010 at 9:15 am #326402pup
then u need a megger , otherwise how u going to sort it? 😥
July 29, 2010 at 10:31 am #326403bigchrisoioi
not being rude, but how can you do the job without a megger????????
should not every repair be tested?
July 29, 2010 at 11:30 am #326404pup
bigchrisoioi wrote:not being rude, but how can you do the job without a megger????????
should not every repair be tested? well it will interesting to find out .may be he got pat tester ? 😆
July 29, 2010 at 5:36 pm #326405adv
yep got pac 1000.info to helping fix the appliance would be more helpfull cheers 😆
August 5, 2010 at 3:18 pm #326406keithwilliams
even a £2.99 multimeter would give you at least a continuity reading on the element. i have a seaward supernova plus pat tester. it’s the dogs b******* but it cant tell me if the elements open circuit unless its on heat cycle during a power-up test.
like the guys say, get yourself a stand alone insulation tester and you’d have diagnosed the elements status straight away.
finally of course it could take out a fuse. lets say that when it failed it went down to earth but since cooling off that earth fault has “healed” itself.
oven elements do this all the time.August 5, 2010 at 3:35 pm #326407adv
cheers i have a meter mate.just was thinkin never had a dishwasher heater do this before, usualy just a dead short that takes out a 13 amp fuse.can you recomend a insulation tester thats not to pricey and will do the job cheers?
August 5, 2010 at 3:47 pm #326408pup
well you have check motor ,mains filter ,ho let see pump wireing for shorting stats waterleaking, i think i cover most things 😆
August 5, 2010 at 4:02 pm #326409adv
yeh had thing running for half hr with panels of. its must be heater ave told cus cheers
August 7, 2010 at 11:53 pm #326410leavemetogetonwithit
adv wrote:can you recomend a insulation tester thats not to pricey and will do the job cheers?
Last time I looked there were plenty of excellent quality secondhand meggers on e-bay at very good prices. Heck, I sold my old one for a fiver on there when I got a more modern compact one. Was an analogue Eagle cost me £40 secondhand in 1988.
Mike. -
