Re: Diplomat fridge fault
It is not a DIY job as you have to take off the control unit.
You have to turn off the mains supply to the fridge.
Then take the control panel off if I remember you have to take the light switch off by squeezing it top and bottom then pull it off with the spring then you can get to the screw that holds the control on.
You then have to slide the control forward to remove it.
It is not easy unless you are used to working on domestic appliances.
Bob
