Diplomat HJA 8630 wont fill
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat HJA 8630 wont fill
  • #61080
    gic
    I have a Diplomat HJA 8630 dishwasher. I had to remove it the other day to do some work on the work top. When I replaced it and turned on, it performed its usual pump out for about 20 secs, and then just stopped. There is no water flowing into the machine, as I would expect at this point, and no error indicators.
    The water is turned on at the mains and I have checked that there is water pressure at the inlet to the machine.
    I suspect the inlet valve has seized. However before I start replacing this, is there anything else it is likely to be?
    #344772
    bazza500
    Re: Diplomat HJA 8630 wont fill
    First thing to check is if the fill hose has kinked when you’ve put it back in.
    #344773
    gic
    Thanks for the reply. I have already tried that – in fact I have taken machine out and tested it in middle of kitchen floor. No difference.
    #344774
    Specialist01269
    Before replacing anything try re-seating the electrical connectors first. Just moving your machine from 1 point to another & back would’nt normally cause the inlet valve to seize.
    PLEASE REMEMBER: POWER OFF & PLUG OUT FIRST, getting :zap: can seriously ruin your day.
    #344775
    gic
    Just tried re-seating connectors. Still not filling with water. The unit had not been used for a period of 6 weeks prior to being moved. I wonder whether that would have caused the inlet valve to seize (and be nothing to do with me moving it)?
    #344776
    Specialist01269
    That’s possible, a sharp tap on top of the valve with the handle of a screwdriver may release it long enough to prove your point.
