Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › diplomat HJA8630 dishwasher
- This topic has 21 replies, 5 voices, and was last updated 17 years ago by
suedehead1.
March 23, 2009 at 10:05 pm #44478
suedehead1
Participanthi,
i havent seen one of these before it seems to fill or empty for about 10 second then stops and does nothing else no flashing lights no noise nothing.
i was looking for some advice as it is integrated and dont want to go pulling it out if its the pcb,
i checked the connect site and they list no parts available for this model,
thanks.March 23, 2009 at 10:10 pm #281105eastlmark
ModeratorRe: diplomat HJA8630 dishwasher
checked for a blocked drain pump? Its a Beko by the way.
March 23, 2009 at 10:13 pm #281106suedehead1
ParticipantRe: diplomat HJA8630 dishwasher
if i put it onto a program it drains then stops if i change the program it fills then stops,
a beko eh?March 24, 2009 at 7:07 am #281107martinm
last one of these i had doing that it was the flowmeter on left hand side, supposed to bring up an error code but it was not
March 24, 2009 at 8:17 am #281108suedehead1
i dont like to apperar daft but what is a flowmeter?
and is it repairable or is a new one flowmeter required.March 24, 2009 at 10:20 pm #281109leavemetogetonwithit
It’s a magnet stuck to a watermill blade about 3cm dia., housed in a round plastic cover with a reed switch stuck on the side. 😆
Beko have one that costs £3.50 from Connect 1729900100, but whether that’s the one you need I don’t know. The reed switch is the bit that most commonly fails and you will probably find out all about that if you do a search in these forums.
Mike.March 24, 2009 at 11:18 pm #281110suedehead1
thanks very much for the replies how do you know if it faulty?
i really should avoid these things.March 25, 2009 at 7:28 am #281111eastlmark
Mike is correct, the flow meter for this model is 1729900100, not saying that is what is needed though. I did repair a few of these in MFI days but only ever had blocked pumps and a couple of heater failures.
March 25, 2009 at 11:29 pm #281112leavemetogetonwithit
I had a Beko doing similar things, can’t remember exactly, which is why I have that flowmeter in stock. Turned out to be the board which was only about £25 retail IIRC.
Mike.March 26, 2009 at 7:53 am #281113Specialist01269
Flowmeter works on 5 volts, 3 connections: 1 +5v, 1 Negative usually centre terminal & 5v pulsed output.
Check first for 5v supply & negative, then meter across output wire & negative, with water flowing through the Flowmeter you should see a regular stream of ON/OFF pulses at 5v, this is much easier to see on a good Analogue meter. 8)
HTH Andy.March 26, 2009 at 6:53 pm #281114suedehead1
thanks for the reply i am going tommorow to get another look at it.
March 26, 2009 at 7:22 pm #281115Specialist01269
If you want to see the On/off pulses better on a Digital meter you can turn the incoming water pressure down a bit. Good luck mate.
Andy 8)March 26, 2009 at 9:32 pm #281116leavemetogetonwithit
Andy, ‘scuse my ignorance but how do you attach your meter leads to those wires/connectors whilst leaving them in circuit? You must have a connection system I don’t have? What do I need and where can I get/how do I make one?
MikeMarch 27, 2009 at 11:23 am #281117Specialist01269
Hi Mike: No ignorance involved mate, we all have different ways of doing things. Usually with connectors of this type I use AVO ultra fine electronics probes or a colleague uses thin stainless steel pins pushed into the rear of the connector & attaches the croc clips from his meter to these.
Andy. 8)March 28, 2009 at 11:06 am #281118leavemetogetonwithit
Thanks Andy, 💡 I’ll see what I can find in the sewing box.
Mike. -
