diplomat HJA8630 dishwasher
Viewing 15 posts - 1 through 15 (of 22 total)
  • #44478
    suedehead1
    hi,
    i havent seen one of these before it seems to fill or empty for about 10 second then stops and does nothing else no flashing lights no noise nothing.
    i was looking for some advice as it is integrated and dont want to go pulling it out if its the pcb,
    i checked the connect site and they list no parts available for this model,
    thanks.
    #281105
    Re: diplomat HJA8630 dishwasher
    checked for a blocked drain pump? Its a Beko by the way.
    #281106
    suedehead1
    if i put it onto a program it drains then stops if i change the program it fills then stops,
    a beko eh?
    #281107
    martinm
    last one of these i had doing that it was the flowmeter on left hand side, supposed to bring up an error code but it was not
    #281108
    suedehead1
    i dont like to apperar daft but what is a flowmeter?
    and is it repairable or is a new one flowmeter required.
    #281109
    It’s a magnet stuck to a watermill blade about 3cm dia., housed in a round plastic cover with a reed switch stuck on the side. 😆
    Beko have one that costs £3.50 from Connect 1729900100, but whether that’s the one you need I don’t know. The reed switch is the bit that most commonly fails and you will probably find out all about that if you do a search in these forums.
    Mike.
    #281110
    suedehead1
    thanks very much for the replies how do you know if it faulty?
    i really should avoid these things.
    #281111
    Mike is correct, the flow meter for this model is 1729900100, not saying that is what is needed though. I did repair a few of these in MFI days but only ever had blocked pumps and a couple of heater failures.
    #281112
    I had a Beko doing similar things, can’t remember exactly, which is why I have that flowmeter in stock. Turned out to be the board which was only about £25 retail IIRC.
    Mike.
    #281113
    Specialist01269
    Flowmeter works on 5 volts, 3 connections: 1 +5v, 1 Negative usually centre terminal & 5v pulsed output.
    Check first for 5v supply & negative, then meter across output wire & negative, with water flowing through the Flowmeter you should see a regular stream of ON/OFF pulses at 5v, this is much easier to see on a good Analogue meter. 8)
    HTH Andy.
    #281114
    suedehead1
    thanks for the reply i am going tommorow to get another look at it.
    #281115
    Specialist01269
    If you want to see the On/off pulses better on a Digital meter you can turn the incoming water pressure down a bit. Good luck mate.
    Andy 8)
    #281116
    Andy, ‘scuse my ignorance but how do you attach your meter leads to those wires/connectors whilst leaving them in circuit? You must have a connection system I don’t have? What do I need and where can I get/how do I make one?
    Mike
    #281117
    Specialist01269
    Hi Mike: No ignorance involved mate, we all have different ways of doing things. Usually with connectors of this type I use AVO ultra fine electronics probes or a colleague uses thin stainless steel pins pushed into the rear of the connector & attaches the croc clips from his meter to these.
    Andy. 8)
    #281118
    Thanks Andy, 💡 I’ll see what I can find in the sewing box.
    Mike.
