This is a four in line ceramic hob. From the left, number two was on. Burning smell for a few secs and then MCB tripped (and would not reset, even with hob isolator off).
Investigation showed burned mains terminal in hob. Replaced mains terminal.
Now both RHS elements work but LHS ones don’t, however there is an audible click as they are switched on (relay), and there’s continuity across both elements.
Thinking it may be PCB damage on the switched side of relays, but no visual clues on board. Trouble is, QER don’t list this one, and new replacement is mega bucks.
Any thoughts much appreciated.
