I have the popular beeping and error code F7 when attempting to put a program on.
I’ve removed the side fill and cleaned it out, even though it didn’t look as if it needed it.
Also took the connector off the small pcb and given that a slight clean.
The tiny fuse looks fine as does everything else.
When it fills, it looks like everything is ok, even the small impeller spins and water goes into the appliance. But as soon as the beeping and F7 occurs, it pumps the water out.
My questions are, if I buy a new side fill (£62’ish), will it solve the problem or could it be something else?
If I was to get a new integrated dishwasher, is it difficult to remove the matching kitchen door from existing appliance and fit it to a new appliance?
Thanks for any help.
