Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat intergrated dishwahser ADP 8132
- This topic has 26 replies, 9 voices, and was last updated 22 years, 2 months ago by
jcb208.
January 14, 2004 at 4:32 pm #5063
jcb208
ParticipantCan any body please advise me what this error code is before I call an engineer incase it is something I can repair easily.
The machine starts the program, begins to fill then will empty out.The first 3 program lights on the display flash ,the 4th is off and the 5th is on.
Any help will be appreciated.
Thanks JohnJanuary 14, 2004 at 4:51 pm #108519Martin
ParticipantRe: Diplomat intergrated dishwahser ADP 8132
Is this a Moben Kitchens dishwasher?
Not sure what your problem is but all dishwashers when they start a programme DRAIN FIRST (not fill) so possibly your problem is an ANTI FLOOD DEVICE problem? In other words the water level system is interupted by a blockage or leak?
Not familiar with the model number to help further…sorry!
January 14, 2004 at 5:01 pm #108520jcb208
Thanks for that quick reply The machine is a branded MFI one,(dont know who makes it) the machine does pump out when first started, then fills a bit then pumps out again this is when i get the error beep and the light sequence on the program display
January 14, 2004 at 5:07 pm #108521Dave_Conway
Hi John, this is an error which occurs occasionally with these models. The PCB needs to be reconfigured to recognise which type of pressure system it has fitted. Generally no parts are required to rectify this, but you will need an engineer with the relevent information supplied by MFI to sort it out for you.
Please put you’re postal code area and I’m sure someone here will be be able to assist further should you decide to call an engineer.
Hope this helps.
January 14, 2004 at 5:19 pm #108522jcb208
Thanks Dave, my postcode is GU149LG
January 14, 2004 at 5:26 pm #108523Dave_Conway
jcb208 wrote:Thanks Dave, my postcode is GU149LG
You’re welcome, can anyone help John out with a call in that postcode ?
January 15, 2004 at 6:17 pm #108524Toni
Not sure if this helps but, I had a ADP8224 flashing fault code E2 recently.
I found the side chamber was blocked completely (The hose that leads to the sump from it also blocked) I took the side chamber off (Very easy) & cleaned it the best I could & hey presto, problem sortedRegards
Toni PazJanuary 17, 2004 at 2:59 pm #108525machineman
try turning water pressure down to a trickle if water pressure is to high it will operate pump cheers dave
January 17, 2004 at 3:36 pm #108526kwatt
KeymasterYeah Toni it often is the side chamber and the bottle brushes IKEA do are excellent for cleaning them out, as are some of the baby bottle ones. 😉
But if they are badly blocked it’s sometimes better just to change the chamber but I can’t remember if that one needs a kit or not.
January 17, 2004 at 4:47 pm #108527jcb208
Thanks for every bodys advise,I have tried turning the water presure down, dos not make any difference..Now have got the side of the machine off, run it and the blue platic side chamber fills up to about half way before it emptys, If there is a blockage where will it be and what will I have to remove to check for a blockage.Thanks John
January 17, 2004 at 8:09 pm #108528machineman
Participantwith the first three lights flashing it is definately the pcb needs resetting two minute job all you need is the know how to reset it. dave
January 18, 2004 at 12:11 am #108529admin
KeymasterRe: Diplomat intergrated dishwahser ADP 8132
O.K thanks looks like I will have to call MFI and book a service call,another day off work, unpaid 🙁 Thanks
January 25, 2004 at 6:44 pm #108530DentedPorsche
OK. First off I don’t know offhand what the error code is, I normally have to call technical for that. From memory my guess is, safety stat has tripped. Located beside the heater. Some have a reset button, some don’t. If no reset button, gently prise the cover off and press down on the centre of the contacts to reset.
The blockage in the sump/airbrake line normally gives 1 and 5 flashing, the actual fault for this code is anti flood device activated.
Is the appliance brand new? or has it been working for some time?
If not new then there may be a blockage in the pressure system somewhere, turning down the water inlet pressure may work as the water will have more time to pass the blockage before activating the overfill. You should also note that these machines have to fill within a certain time or you get another error up.
If it’s brand new, check that the drain is high enough or you’ll be losing water as quick as it fills. Other thing to check is under the sink, has the spigot still got it’s plug in?
Resetting the pcb is quite easy. Sadly, although I can remember how to get it into diagnostic mode, I can’t remember how to get it out again. I’ll try and remember to ask next time I speak to technical.
Hope this is of some help to someone.January 28, 2004 at 4:11 pm #108531jcb208
O.K its all sorted now thanks to bonzaco who mailed me the Pc board reset instructions,saving me a call out charge at least 😀
January 31, 2004 at 10:36 pm #108532admin
Toni,
we saw your message posted recently about the dishwasher ADP8224 and your E2 error code. Has the problem recurred? Do you know a number for Diplomat Customer Care? How do we get to that side chamber you mentioned, to clean it out? The instruction book we have says that error code E2 is not used on model ADP8224 but it is coming up all the time on our machine and now it stops about 5 min into the cycle and won’t go any further.
Rgds
Malcolm & Jo
