Diplomat Module?
  • #37991
    happycack
    Integral Diplomat 8512/1 (Servis to us) got a weird problem. Any fill section the inlet valves just pulse fills about every 3 seconds. Couldn’t wait for it to fill at that rate. No motor action on spin section, only pump, and the programmer doesn’t advance. I’m guessing at the module. A label on the base of the machine tells you not to use the module for this model! It says 546021400. This checks out to be for a Servis machine priced at about £55.00 plus vat. IS it likely to be any other fault you lot may have come across before I order a new module?
    Paul.
    #257346
    Dales-Electronic
    Re: Diplomat Module?
    There are two types of motor fitted to this machine, one uses an induction motor the other a brush type that why you must fit the correct module. Regarding faults, check belt tension and heater insulation. You could get a guaranteed recon module from EMW – http://www.emwelec.co.uk
    #257347
    happycack
    Thanks for that, I’ll get onto it. 😀
    #257348
    wilf
    pressure switch?
    wilf
    #257349
    SWERV
    Had this quite a few times, always been the module.
    Merv
