diplomat oven
  • #33915
    petalpop
    model adp4500
    058587039
    serial 00606257
    need the part numbers for the outer door glass and both hinges for the main oven
    complete door would be good if its available
    cheers
    #240564
    petalpop
    Re: diplomat oven
    anybody please 😥 🙁 😥
    #240565
    NWAR
    Re: diplomat oven
    Main oven outer door glass is 012385484. I don’t see a listing for a complete door though
    Hinges aren’t sided and they don’t come as a kit, it’s separate parts:
    – hinge bar (main hinge part) 011542003
    – spring 081555700
    – front guide bush (hinge receiver) 081538700
    – rear guide bush 081538800
    There’s also two versions of the hinge pin depending on the range:
    Classic and Standard versions use 12mm pins 081557301
    Softline versions use 16mm pins 081557300
    #240566
    petalpop
    Re: diplomat oven
    cheers nwar
