Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Diplomat Oven Mod. Select 920/AHY 4440
- This topic has 11 replies, 5 voices, and was last updated 16 years, 8 months ago by
Miketheleak.
July 21, 2009 at 5:56 pm #47251
Miketheleak
ParticipantHi
Has anybody got a wiring diagram for this oven please and also how on earth do remove the grill energy regulator? I’ve tried to work out how to remove the fascia panel but its covered in grease and muck. I’m sure its really simple and I’m missing something very obvious and I will deserve any funny comments.
But please can somebody point me in the right direction.July 21, 2009 at 9:55 pm #292846karv
ParticipantRe: Diplomat Oven Mod. Select 920/AHY 4440
i can suggest a few possible ways it comes of , i can,t remember which one this is
1 type facia just pulls of with a small pole on left and right that goes into oven
1 type 2x 2 screw from behind facia on left and right that u unscrew1 type screws on top left and right hand side of oven that go inwards towards oven then u have to leaver facia out from bottom its abit arkward and uncrew screws along top behind facia .
some oven use to screw in with few screws from below facia as well, some are just for the timers tho.
it might be one of theseJuly 22, 2009 at 2:13 pm #292847Miketheleak
Thanks Karv any chance of a wiring diag anybody?
Mike.
July 22, 2009 at 2:30 pm #292848kwatt
KeymasterOn the way to you now.
July 22, 2009 at 3:02 pm #292849Miketheleak
Thanks very much at least now I know what I’m looking for, but I think I’ll put extra swarfega in my van this time. 😆
Mike.
July 22, 2009 at 5:31 pm #292850pup
Miketheleak wrote:Hi
Mike.
for your hands i hope 😆July 23, 2009 at 8:48 am #292851Miketheleak
You mean there are other uses for swarfega, tell me more. 😯
July 23, 2009 at 11:24 am #292852roly16
From the exploded view it looks as if there are 2 screw holes either side of the steel rear fascia panel. There’s no indication of how the glass is secured to the rear fascia panel; possibly by clips that lever out, or brackets glued to it that are screwed through into the side holes.
July 23, 2009 at 11:38 am #292853Miketheleak
Would it be possible for you to let me have the exploded view please?
July 23, 2009 at 1:49 pm #292854roly16
No, unfortunately you can’t copy or print the diagrams off the CD; I tried.
Geoff
July 23, 2009 at 2:02 pm #292855Miketheleak
Thanks very much anyway.
August 3, 2009 at 8:32 pm #292856Miketheleak
It turned out to be simply a matter of removing the trim from around the whole oven, it’s like a picture frame and is just pushed in to clips. Once that was off all screws and fixings are visible. It can be a might stiff if its mucky though.
