Re: Diplomat oven – no symbols!!
a lot of diplomat ovens have the model number on amother label on the top of the oven
undo the screws that hold the oven in and slide it out 6 inches most of the time you will then find carroect model
be aware if you pull it out too far oven will tilt forward so get help if oven high off floor
once you get correct model we can see if panel is still available
count how many positions there are on the main switch to get an idea of how many options you have
poss answers
grill :: may be 2 positions for grill half and full. thermostat has to be turned up to make grill come on
fan oven :: you have already found this
light :: some oven have a light only postion normally the first click clockwise
defrost oven fan running no heat
more complex ovens also have
convection oven ( top and bottom elements)
lower element only ( under floor of oven)
top element only
you instruction book will help with this
hope it helps
