Diplomat Oven not heating over 120C
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat Oven not heating over 120C
  • #71852
    inewton
    I have a Diplomat ADP4500 which, on the main fan oven will not get up to teperture, the fan is working and I have changed the circular heat element and the thermostat but to no change. Heat element comes on, thermostat light go out after a few minutes, but no matter what setting, will not rise above 120 degrees C.
    Any thoughts as to what else could be effecting it?
    #382564
    Washman
    Re: Diplomat Oven not heating over 120C
    Have you fitted the thermostat sensor in the correct position.
    Washman
    #382565
    inewton
    Thanks for the reply.
    I ahve put it in the same position as the original (i think)will double check!
    #382566
    inewton
    the themostat sensor is in the correct location!
    Any other thoughts?
    #382567
    BobHope
    it looks like your oven is a multifunction type, please decribe which setting you are using on the function switch
    Bob.
    #382568
    inewton
    This is a double oven and it is the main fan oven that is not working correctly, the top oven/grill works fine.
    The fan is operational on the main oven but on turning the selector knob on the light comes on but the temperature doesn’t get to that selected (verified by separate thermometer) the temperature light goes out before reaching the desired temperature at about 120 each time.
    Not sure where to try next with it, so any help would be appreciated
    Regards
    Ian
    #382569
    BobHope
    set the thermostat to 80c when the temperature indicator goes out
    turn the thermostat up to 100c and tel me if the indicator light comes back on.
    Bob.
    #382570
    inewton
    The light doesn’t seem to want to come on at all now (the light flashed on momentarily)and the oven not heating in the slightest,!?!
    Could it be the selector switch?
    Ian
    #382571
    inewton
    Found the problem, the TOC is not working, bypassed it and all ok
