Diplomat Oven Temperature Light stays on – HELP!
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat Oven Temperature Light stays on – HELP!
  • #29970
    PoohBear
    My Diplomatic Oven temperature light stays on – when I am cooking it goes off and once the oven has cooled down it stays on – is this right or is there a fault?
    #225372
    Re: Diplomat Oven Temperature Light stays on – HELP!
    If the oven goes cold when you have set the oven temperature back to zero, I really wouldn’t worry about it – there may be a very slight earth leak allowing power to the neon.
    If the oven does not fully cool, it needs some attention……..
    Click the link below for a UKW engineer in your area.
    PoohBear
    Thank you!
