Diplomat Oven Thermostat
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat Oven Thermostat
  • #5469
    I’ve just moved into a place with a Diplomat ADP 3101 oven installed. Everything works, but the oven gets extremely hot, especially the fascia with the dials. Also, the oven ready light does not go off although the oven is obviously sufficiently hot (only goes off when you turn the dial right down. Is this a thermostat problem? Or something else? If so, is it easy to replace? – HELP!
    #111478
    From the fault described it’s almost certainly a thermostat failure. The part is available easily, part number 76X3759 and is listed at £29.98 excluding VAT and carriage.
    If you use the helpdesk function Dave will get you one pretty rapidly if you want one. I don’t know if they are in stock with Dave, but they will be with the manufacturer I should imagine.
