Diplomat Select 610
Home Forums Public Support Forums Spare Parts Help Diplomat Select 610
  • #7962
    Hi there folks…
    My Diplomat Select 610 electric slot in cooker door has fallen off!! 😕
    The problem seems to be that the metal ring thingys attached to the spring mechanism has “stretched” over the last few years and the ring bit that attaches to it has split. Was just about to go buy a new oven when i stumbled across this forum so i thought maybe….just maybe someone would know if i can buy replacement parts or if there is no hope and i have to buy new.
    If i have to buy, then could anyone suggest a model around the 200-250 pound mark that is a good buy. (brushed aluminium)
    Thanks for any replies in advance…. sourface
    #126154
    Dave_Conway
    Re: Diplomat Select 610
    Sourface, if you can post the model number from the rating plate please (should be around the door(s)) beginning APL or AHY or similar, I’ll check it out for you.
    #126155
    Thanks Dave…
    I had to unscrew the thing and pull it out from the unit….but found it 😀
    it is AHY3300
    #126156
    Oops… 😯
    forgot to enter a username last time but it was me
    #126157
    Dave_Conway
    Ah, it’s one of those type.
    Is it the metal parts that go in to the oven that have broken ?
    #126158
    Well not exactly…
    Its the part that is attached to it…there are 2 metal holes that a small rod goes through…attached to the spring which holds the door ajar etc…the holes have stretched out and snapped so wont stay the on the small rod
    #126159
    Dave_Conway
    Can you send me an email please and I’ll reply with a picture, it won’t be until tommorow now though as I’m going home shortly 😉
    #126160
    Sure thing Dave…
    Thanks for helping
    #126161
    email sent….. 🙂
