Diplomat Select 610
  • #14242
    Daz2
    Can anyone help?
    I recently moved into a house and the cooker is a Diplomat Select 610, model number AHY33**.
    The problem is that the previous owner has scrubbed all of the temperature graduations from around the control knob!!
    Can anyone give me an idea of the temperatures at 3 o’clock, and 6 o’clock. I can see part of one at 8 o’clock – it ends in 50, is that 350??
    Daz
    #158743
    NWAR
    Re: Diplomat Select 610
    Daz2 wrote:is that 350?
    I should hope not; the temperature will more than likely have a maximum temperature of 250’C.
    Where you hear the thermostat ‘click’ when you select the temperature should be around 50’C. Starting at that point to the max. point (250’C) you can work out approximate temperatures on the intervening settings.
    If you could get the last two digits of the model number we could be more precise for you.
