Diplomat Select 610
  • #18417
    brotherpipi
    Sorry – can’t see model no. on it.
    Electric oven/grill stopped working due to accidently switching off from wall socket. Then it started working again after a bit of fiddling with the time / alarm thing (which we never use). Then it stopped working again!! (again after switcing off at wall).
    What did we do to make it work again??!!
    Thanks for any information you might have for me
    Paul
    #178938
    Re: Diplomat Select 610
    Take it that it’s a flourescent display timer? Time must be set, and the hand symbol showing (unless you actually set the programmer) for the oven to operate.
    600 series encompasses over 40 machines from a variety of manufacturers, so it’s difficult to be more exact.
    brotherpipi
    Thanks. My Model is AHY3300. Not sure if the clock display is flourescent because it doesn’t tick or seem to be working at the moment. (I’m sure it was last week when it started up again, but I don’t think it ever worked before that when the oven was working fine).
    I have hand symbol showing (at 9 o’clock).
    The red hand moves with the hour hand on clock when I’m changing the time. I can’t seem to move it separately (even by pulling out top button and twisting). You can probably tell I’ve just been twisting knobs hoping that something triggers the oven on!!!
    Any ideas?
    Paul
