Diplomat select 610 – Fan not turning
Home Forums Public Support Forums Spare Parts Help Diplomat select 610 – Fan not turning
  • #9646
    sideshowmel
    Please please can some one help me. The fan on my diplomat has stopped turning. Any helpful suggestions please…
    #135051
    Dave_Conway
    Re: Diplomat select 610 – Fan not turning
    It’s probably the fan motor itself, we’ll need the model number beginning APL, AHY… to identify though please.
    It should be around the door or on the oven roof.
    #135052
    sideshowmel
    Cheers Dave. The model number is AHY33. Do the motors normally go on these models? Also are the quite expensive? 😕
    #135053
    Dave_Conway
    Fan motors can fail on any make or model Mel.
    Not too expensive though at £39.74 inc VAT and delivery, if you’d like one, an email to spares@ukwhitegoods.co.uk please, remember to disconnect the oven 1st :plug:
    If you’re unsure, please check repairs@ and the directories for an engineer.
    #135054
    NWAR
    There’s 2 versions of this listed – AHY3310 & AHY3320. Luckily they both use the same fan motor (0FANMTRB), but check the model number in full to make sure it’s not something other than the two above.
    It may be that the impellor has seized with gunk – a bit of lube & elbow grease may do the trick.
    Craig
