Diplomat select 620 Door has fallen off!
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat select 620 Door has fallen off!
Viewing 5 posts - 16 through 20 (of 20 total)
  • #265923
    Re: Diplomat select 620 Door has fallen off!
    ODASSY36 is available so far as I can see but it isn’t listed online currently. If required I can add it but you’re looking at about £80 plus VAT for it and that is only the outer door with the brackets on it, it does not include any other part of the door.
    It would take a few days to get one in for you.
    The hinges are as Chris posted.
    HTH
    JJHawk
    So if i contact MFI with this partnumber you believe it may be possible?
    #265925
    JJHawk
    Kwatt,
    I would like to order this part, how can i get this from you?
    J
    #265926
    Dave_Conway
    Found some ODASSY36 😀
    http://shop.ukwhitegoods.co.uk/advanced … &x=20&y=10
    #265927
    caucau
    Evening,
    Similar problem to the bloke who started this thread, although my door’s OK, it’s just the hinges that are broken.
    I’ve got two new hinges, but (slightly embarrassingly :oops:) can’t work out how to use the bloody things.
    I just can’t open them at all. Does anyone on here know them well enough to be able to explain how to open the hinge? There’s a small retaining clip which doesn’t seem to make any difference. can’t see anything else to release/press/turn…
    Would be grateful for help.
    Thanks.
