Diplomat Select 620 Oven – glass has smashed!
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat Select 620 Oven – glass has smashed!
  • #6992
    kyler
    Hi, the glass on the inside of my oven just smashed for no apparent reason!! Does anyone know where I can buy a new sheet of glass?? I’ts for a Diplomat select 620 – AHY36**
    Any help would be greatly appreciated, Thanks
    #120797
    Hi Kyler,
    Yes you can indeed get a new glass, Dave or I will get back to you in the morning with a price etc.
    However, we may need the full model number, including the two digits that you’ve starred out. 😕
    kyler
    Re: Diplomat Select 620 Oven – glass has smashed!
    Thanks for the reply mate very grateful, thing is I just copied the model number off the instruction manual, it reads AHY36** no idea what the last two digits are?? Sorry! Thats the only details I know apart from it being a Diplomat Select 620 multifunction oven.
    Don’t know if this helps!,
    kyler
    #120799
    If you pull down the oven door and have a look there should be a rating plate there that will give you the full model number and serial number. It’s around the edge of the cavity or the actual door itself usually.
    kyler
    Good call mate, you were right, the full code is AHY3601.
    Thanks a lot!,
    Kyler
    #120801
    kyler
    should have also said that the serial number is 03148330.
    Thanks again
    #120802
    No problem, we’l have you an answer in the mornign on that, should be easily doable with 5 days or so even as a special order. MFI are pretty good all things considered.
    Dave_Conway
    Hi Kyler, it’s £40.80 inc VAT and delivery.
    Drop me an email to spares@ukwhitegoods.co.uk if you need one ordered up and I’ll arrange for you.
