Diplomat Select 620 oven not working. can anyone help.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat Select 620 oven not working. can anyone help.
  • #78674
    charlitf
    I have a copy of they manual and think it is a AHY36*** as this matches the oven, though the oven has no code on it. My child has pressed buttons and now the oven does not work. I have turned it off for an hour and then on. The timer does not flash, but has the words auto to the left edge and 0.00 as a time. Can anyone help re kick this into working please.
    #406508
    Re: Diplomat Select 620 oven not working. can anyone help.
    You can find generic oven timer instructions here:
    http://www.ukwhitegoods.co.uk/help/fix- … -dead.html
    charlitf
    i have tried pressing the manuel button, nothing happens at all bar the time flickers at me.
    #406510
    It is possible that the clock is faulty then or that the button isn’t connecting properly.
    Andy jones
    Make sure none of the buttons have stuck in, should be easy to pull them off and give them a quick clean, if not then looks like a faulty timer
