Diplomat Servis 8512 no volts to drain pump Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Diplomat Servis 8512 no volts to drain pump This topic has 3 replies, 2 voices, and was last updated 17 years, 4 months ago by Simon46. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts November 25, 2008 at 1:03 am #41297 Simon46Participant This one has had inlet hose water leak onto floor so everything covered in condensation. would this be from a module fault (DMPA1000) or could it be timer. Heater is ok. S. November 25, 2008 at 1:21 am #269464 Penguin45Participant Re: Diplomat Servis 8512 no volts to drain pump Only direct timer function is to lock the door. Otherwise, it’s a selector switch. No volts to pump is a module fault. Chris. November 25, 2008 at 8:09 am #269465 Simon46Participant Re: Diplomat Servis 8512 no volts to drain pump Will EMW it. Many thanks Chris S. November 27, 2008 at 8:47 am #269466 Simon46Participant Re: Diplomat Servis 8512 no volts to drain pump Module it was. 😀 S. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
