Got this machine with an overfill problem.
Tried module from EMW but same fault remains.
Did usual tightening contacts etc.
There is slight heat mark on a pressure switch contacts insulation sleeve – I presume the pressure switch only involves the heater, it sounds positive.
Is it just a timed fill on these so could be a faulty timer?
It sometimes fills ok at the first fill and will heat but when it reaches rinse it overfills and when it gets nearly to top of window glass, pump comes in but just makes a ‘struggling’ clunking noise. Click timer on and it pumps the water out ok.
Any insights would be welcome.
Laurence
