Diplomat SIngle Built-in Oven ACA3200 Serial 0711460090
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat SIngle Built-in Oven ACA3200 Serial 0711460090
  • #51697
    dimebars
    Hi folks
    We have owned the above oven for around 18 months as part of an MFI kitchen package.
    Around 3 months ago, the LED above the temperature knob “exploded” and since the oven has not worked.
    The LCD display etc still powers up when the oven is switched on, but nothing else wants to function.
    If the oven is powered up, and the oven function selected, when selecting the required temperature there is a loud bang and a flash from the blown LED.
    I cant find a wiring diagram anywhere to trace a short which I can only assume this is.
    Its not wired via 13amp socket, but via a 45amp (i think) cooker switch.
    Are wiring diagrams available for these at all or has anyone else came across a similar problem?
    Was it easy (cheap!) to fix or am I as well biting the bullet and getting a new oven?
    #309006
    karv
    Re: Diplomat SIngle Built-in Oven ACA3200 Serial 0711460090
    if there a loud bang somthing is arking if u take the top of i don,t think it will be hard to see , and most likely to be the neon neon wire or thermostat , take a couple of clear pictures before u pull any wires of and make sure its isolated . if the neon is in bits my guess would be thats your problem, you will probally see black burn marks somewhere
    #309007
    dimebars
    Yeah the neon was toasted the first time it blew
    You think replacing the lamp and cover will be enough to solve the problem?
    #309008
    As a temporary measure, disconnect it completely and see if you get function.
    If you contact spares@ukwhitegoods.co.uk with your model info, they should be able to source a suitable replacement for you.
    Make a note of where the wiring fits – we won’t be able to help you if you don’t.
