Diplomat (Smeg) ADP8242 stops.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Diplomat (Smeg) ADP8242 stops.
  • #51493
    aqualectric
    Diplomat ADP8242 integrated dishwasher. Smeg built unit. Nr:- 31992 0203.
    Reset the PCB and restart new program. Machine drains, fills, washes for about 2 minutes then everything dies. Only fault found was a burnt wire to the heater terminal. Cut and retagged. Heater checked out; continuity and no insulation issues.
    Fill, pump, wash motor, checked dispenser solenoid (although it was one using a heat coil type unit, not a standard solenoid), checked mains filter – all OK.
    I am thinking duff PCB – have I missed anything? If it is the PCB, anyone have a part number please?
    Thanks,
    Steve.
    #308261
    Re: Diplomat (Smeg) ADP8242 stops.
    All that’s left is the pcb – 816290672
    aqualectric
    Cheers, Chris.
    Steve.
