Diplomat Softline 920G (ADP0300) oven light/ignition/clock
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat Softline 920G (ADP0300) oven light/ignition/clock
  • #18627
    The light, ignition and clock have stopped working, but the fan is working. There is a plug which works the fan and is OK and presumably works the above as well.
    Is there a fuse or cut-out switch in the oven itself, if so where? The grill may have got over heated. How do I repair this?
    #179677
    gegsy
    Re: Diplomat Softline 920G (ADP0300) oven light/ignition/clo
    With this unit being a gas appliance, you must get a Corgi engineer to repair it for you.
    Find a Corgi engineer here
    An engineer from Stoves came and fixed the problem. All it need was for a cut-out switch in the oven to be reset. Unfortunately this was described in the user manual I got from MFI.
    The problem was caused by closing the grill door with the grill still on causing it to verheat.
    To get to the switch you need to unscrew the front of the oven which secures it in the cabinet, then pull the oven out slightly to get to the top panel. Unscrew the front of the top panel and reach inside the the front left to the cut-out switch and reset it with a screw driver.
    Apparantly the newer version of this oven (mine I bought in year 2002) has the cut-off switch in a more accessible position.
    #179679
    Scott68
    Me too
    I’ve had this same problem but can’t seem to find this reset button. I’ve poked a screwdriver in every hole I can find at the back of the clock panel, but no joy….
    Can anyone help with some specifics re the reset botton location?
    #179680
    no1smiles2000
    I also have the same problem, will have a look tonight and post whether i am successful!
    thanks for the help, glad i found this website has saved me a hefty call out fee! 🙂
    thanks Katie
    #179681
    no1smiles2000
    just fixed mine!
    you need to unscrew the oven, pull it out completely and put it on the floor……….
    __________________________
    I’m sorry, we cannot let you publish gas repairs as a private individual. Any gas appliance servicing must only be carried out by a CORGI registered engineer. If we let this post stand, you would be liable for the big bang when some other amateur attempts the repair and gets it wrong………
    Penguin45,
    Moderator,
    UKWhitegoods.
    #179682
    helo_75
    erm, please dont post advice about dismantling gas ovens in a public forum
    as previously stated, u need to have a corgi registered engineer to repair your appliance, regardless of how easy it is
    the law’s there for safety reasons
    and it doesnt matter if your only repairing the electric side of it, the machine still needs to be purged and drop tested to ensure safety
    thanx
