diplomat, top oven and grill not working but the fan is?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum diplomat, top oven and grill not working but the fan is?
Viewing 15 posts - 1 through 15 (of 15 total)
  • #80624
    russ77
    i have a diplomat double oven ,
    the bottom oven is fine, but both the top oven and grill have stopped working at the same time, even though the fan still comes on?
    iv looked at the element of the grill and their are no breaks.
    I had to replace the bottom element last year and that’s working perfectly.
    can any 1 help please?
    #413507
    Re: diplomat, top oven and grill not working but the fan is
    You didn’t provide us with the all important model number but in the absence of that vital info have you checked the thermal trip?
    #413508
    russ77
    the mod number ADP4520
    and what is a thermal trip?
    and how hard is it to check and replace?
    #413509
    russ77 wrote:and what is a thermal trip?
    russ77 wrote:and how hard is it to check and replace?
    You will need a multimeter and a screwdriver.
    #413510
    In that oven it’s this one…
    http://shop.ukwhitegoods.co.uk/50200900 … thermostat
    russ77
    thanks for your help
    #413512
    russ77
    Hi iv just go the part that you suggested but I think it’s the wrong part!
    Iv open the top and this is the pic of the top of the oven.
    #413513
    russ77
    Oven make!
    #413514
    russ77 wrote:Hi iv just go the part that you suggested but I think it’s the wrong part!
    You’ve taken a photo of the selector switch and oven thermostat. The part we refer to is fitted on the oven carcass. Take another look elsewhere to find it.
    #413515
    russ77
    I located where is?
    I switched around the bottom trip with the top trip, as I know that the bottom oven works and I want to see if top oven would work with the bottom trip in!
    Unfortunately the top oven and grill are still not working and the bottom oven works!
    So it’s not the trips, so have you got an more ideas please?
    #413516
    Jackal
    russ77 wrote:so have you got an more ideas please?
    Yes, get someone whom knows what they are doing in to look at it, as your clearly out of your depth on this particular item.
    Jackal
    Sent from my iPhone using Tapatalk 2
    #413517
    Jackal
    Yes
    Get someone in whom knows what they are doing.
    Safety is the primary thing here. Swapping parts around you don’t know about, know if they are compatible or not, especially safety devices is NOT safe.
    Jackal
    #413518
    Here! Here! To that sentiment.
    #413519
    russ77
    Thank for your input! but swooping 2 fuse around that are identical is not particular hard! And for safety go’s I may not be a white goods engineer, but I’m quite confident in my own abilities!
    #413520
    Jackal
    Confidence and competence are two separate things!
    I have no doubt you have the former but from your posts I seriously suspect you lack the latter.
    Jackal
