Had a problem with the drum slowly filling after cycle completion – and then leaking out onto the floor. I took both inlet valves off and connected the mains water to each. The cold held, but the hot has a slow drip.
On the basis that I need to replace the hot inlet valve – can you suggest the part no – or shd I just call your store? It was closed at time of writing – hence the note.
