Diplomat Washer Dryer
  • #50403
    pegasusk7
    I have a Diplomat Washer Dryer model 8702, serial no. 20053513845 which fails to run any programme. Lights are on, door locks then zilch. PCB? Or any other suggestions?
    Phil
    #304699
    happycack
    Re: Diplomat Washer Dryer
    This is a Sevis variant and I’ve found that 9 times out of 10 it’s the board.
    Could always check the multiblocks for a poor connection due to vibration but doubt it. Check the board visually, sometimes find an obvious burn point. Expensive too.
    #304700
    PGS
    I ditto happycack
    #304701
    look at the pcb if there are two large resistors normally around 6k
    put meter across them you should get around 3K as they are in parallel
    if higher replace and normally cures it
    if you cant get pm me
