I have the above Dishwasher which works well enough apart from the fact that the moulded grey plastic internal dual pipe assy keeps popping out of the bottom white plastic part which resembles an old steam engine funnel. The fragile clips have broken and there is therefore nothing to retain the pipe assy. I do wonder if it is heat which causes the plastic to warp and therefore put undue force on the lower clip section?
Tube assembly – (265) 4812 530 29118. £30 odd from memory, plus vat etc. Email to spares@ukwhitegoods.co.uk for prices and ordering. The 265 is if you want the part from Diplomat rather than Whirlpool – it’ll cost you more……….
Thanks for quick reply……but just to clarify,
It is the white plastic funnel-shaped part I need (mounted I think with four screws horizontally on which the lower spinner arms are also mounted), rather than the grey tube assembly…..or is that the part you meant?
The part secured by the screws which the tube clips in to is 481241818341 at £10.73 plus carriage, that’s the bit that normally causes this problem 🙂
