Diplomat/Whirlpool ADP8332
  • #41527
    geoff1
    Dishwasher restarts programme at end of previous programme. The lady used to have 10mins to open door at end of cycle before it started again but now restarts straight away.
    Has anyone had this before?? I can only think that it may be module related but claims this was changed some years back for the same fault but did not cure it.
    8454 002 15820
    Any information would be helpful
    Geoff
    #270482
    Re: Diplomat/Whirlpool ADP8332
    yep, had a couple of them in the past on the older 2 board models, after changing the main pcb down below with no luck it turned out to be the user board in the door. Pretty sure the one you have only has the one board so it should be easier.
    #270483
    geoff1
    Thank you for advice. will go for user board as only one fitted
    Geoff
