Cant seem to find info on this fault this one has a pressure switch not a flowmeter: switch on to any program, shut door, drain pump starts then stops but will not fill then constant bleeps.
No leaks, inlet solenoide OK no power to solenoide, heater OK.
Been back to this one today, Bleeps when door is shut and led next to the start button flashes continuously on any program drain pump runs for about 30secs then stops but it still bleeps and flashes all the time.
Can’t seem to enter diagnostics mode it still continues through the same cycle as above.
the only fault code that can look like this is 1. 1 flash then a space then 1 flash etc
this is NTC but if its not its the pcb i noramlly keep a test ntc to try this
just measure my test one at room temp today and getting 55K ohms
buy a similar resistor disconnect ntc and replace with resistor and see if fault stops. obviously you cant run it for long it will overheat but its a cheap test
