diplomat8132 intermitant fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum diplomat8132 intermitant fault
  • #6469
    myke
    hi guys what an interesting forum
    right i have a diplomat 8132 dishwasher which worked fine for 14 months then sometimes it would wash and sometimes not when it washes its fine it fills up and empties ok if i does not work (which it is doing more often now) it just empties fills then empties it beeps at the end of the programme and shows error lights counting from left to right there are 5 lights no 2 flashes and no 5 is illuminated if i then reclose then open the door no 4and no5 flash i read up most of the posts on here about this model and even tried to reset the programmer by tapping the select button 4 times in 3 secs straight after turning on then turning off but nothing has changed any advice or posible solutions would be greatly apreachiated a circuit diagram would also help i believe this is a badged model anyone know the make it is thankyou myke
    #117864
    Anyone going to help myke? I don’t know the answer to this one – doesn’t sound like the usual fill problems. Heater or NTC maybe?
    Re: diplomat8132 intermitant fault
    Sorry, I missed this one. 😳
    The fault described points to an E2 or similar from memory but I or Dave will answer it fully in the morning.
    myke
    not working at all today wont do a cold rinse so i guess that rules out the heater and stat never realy looked but how much water should be in the machine when full1/2″ or more? managed to get an instruction book from a friend at mfi it says 2 and 5 are indeed an E2 error safety level switch tripped
    this water level switch is it a similar type to a washing machine ie a presure switch or is it a float switch? machine is intergrated and i have checked its level
    thanks for the speedy replies guys myke
    #117867
    Okay Myke, this is an E2 error which can be no less than one of 12 faults, although most likely to be a side chamber issue. In all honesty it’s not a job for the DIYer as the sides need stripped and the chamber cleaned or replaced depending on how serious it is if that is indeed the problem.
    There is a pressure switch as well as a safety device for anti-flood protection but much of the fill system is to do with the fill chamber.
    Wiring diagrams we are not allowed to handout sadly without written consent from the manufacturer or the powers that be in this case. 🙁
    I can tell you that the machine is actually manufactured by Smeg so it’s not a bad machine really. 😉
    thanks again for the info will let you know how i get on will take it apart this weekend if i can get he time off work 😉
    #117869
    myke
    hi above post was me dunno why it says guest prehaps i forgot to log in
