Hi first post, have a apm8702 washer dryer that starts ok but after a few cycles it starts to juder, i have taken the back off and the drum sort of starts then stalls and then juddders and will not move on to next cycle.
I have cleaned out the pump and pipes, and also changed the heater element, but still stutters after the initial few tumbles.
The motor circuitry is obviously breaking down somewhere so it’s time to get the meter out. When you’ve checked every circuit known to man you’ll probably end up having to replace the module anyway as thats where the fault usually lies i’m afraid….
hi if the drum starts to go round and stutters and is not able to turn like it don,t have the strengh to turn and then does nothing else and just clickes around to the end sounds like a capactior to me
