Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Dipolmat – Do all their ovens have a used by date?
- This topic has 8 replies, 4 voices, and was last updated 20 years, 10 months ago by
nichom.
May 24, 2005 at 9:04 am #9755
nichom
ParticipantHi,
I also have a Dipolmat electric grill/oven and the oven part has packed up. The grill still works, but that’s it. I had actually noticed about a month ago that sometimes the fan in the oven didn’t work. Anyway now the fan doesn’t work at all and the oven no longer heats up.
The details are:
Model – ADP3101
Type – B11
Oven – 2,150Kw MAX
Serial No – 5860271000I live in London SW18.
Can someone please recommend who I can call to get this fixed (and how much I should expect to pay)? Also from the other posts on this forum it would appear I need the fan element, is it best to order this first then call a repair guy? Or is it simple to put in myself?
NichomMay 24, 2005 at 9:27 am #135689Dave_Conway
ParticipantRe: Dipolmat – Do all their ovens have a used by date?
If the fan isn’t running it won’t just be the element, it may be the fan motor and the element or just the fan motor.
Have you checked the timer isn’t on automatic as that would stop the whole oven from working ?
May 24, 2005 at 9:51 am #135690nichom
The timer is only a very basic type. It doesn’t have an automatic, as far as I can see. The grill still works when we want.
Doesn’t sound like its going to be cheap!
May 24, 2005 at 10:57 am #135691Dave_Conway
If both were gone I guess you’d be looking around the £100 mark (ish).
Probably worth a look I think as it could cost up to three times that to replace.
May 24, 2005 at 11:06 am #135692nichom
Thanks a lot. Any suggestion of who I should contact for the SW18 area of london?
Should I ordewr the parts now? If it is only one bit can I return the other bit? Also where can I get them from?
May 24, 2005 at 11:34 am #135693Dave_Conway
I wouldn’t order anything until a correct diagnosis has been made, I’ll check this evening for a SW18 contact for you, I have some names at home, unless someone else knows in the meantime ?
I can get the parts should the engineer have trouble himself, although most of these sorts of parts are readily available.
May 24, 2005 at 7:05 pm #135694DentedPorsche
Some of these ovens with the basic timer do have a manual setting, little symbol of a hand. Try turning the timer on, if it now works, look for the symbol and turn it to there.
Gotta be worth a try.DP
May 31, 2005 at 6:45 am #135695nichom
Hi Dave, were you able to find a contact number of someone for the SW18 area?
May 31, 2005 at 7:55 am #135696admin
KeymasterRe: Dipolmat – Do all their ovens have a used by date?
nichom
give me a call we might be able to help if your prepaired for a early call if dave cant find anyone listed
bryan 07961365484
