Re: Disable freezer compartment
gwtost wrote:Is there any way that i can disconnect the freezer compartment allowing the fridge to continue working correctly?
Basically, no. The freezer compartment is the evaporator which in effect keeps the fridge cool.
Won’t a defrost resolve the over-icing problem ? Even if the door is cracked it should work OK after the ice has been removed. Please don’t attack the ice with anything, switch the fridge off and allow it to defrost naturally with the main door open, you’ll have to catch/mop up the water though I’m afraid 🙁
