This machine does not take water in.Aqua stop is OK.level switches OK.Washing pump operates.
I have no service manual, no test diagnostic,so I can do nothing.
Any advice will be wellcome.
OK on the Safety Valve system in this case, then I suspect because you say the washing pump operates, then the problem must be the level switches I would think 🙄
SE24237/37 Dragan? You can find exploded diagrams and parts listings on http://www.bshappliancecare.com – follow links into Partfinder. Personally if you get 3kohms+ across the valve solenoid coil, I’d suspect he computer board.
