disherwasher hotpoint aquaris fdm 550
Home Forums Public Support Forums Help And Support Dishwasher Help Forum disherwasher hotpoint aquaris fdm 550
  • #92069
    mackintyre40
    hi looking for some help,i have the following lights flashing both red lights flashing,rinse aid and salt,and the side of the machine two yellow wash and dry flashing…..the machine will start up put water in after that nothing,turning power on and off,the machine wont drain,once you manual take out the water,the machine start the cycle again its putting water in you can hear it pre washing then stops again then the above flashing lights
    i was thinking drain pump
    any i dears
    thank peter
    #450199
    Re: disherwasher hotpoint aquaris fdm 550
    Ignore salt and rinse aid lights.
    If you have lights 1&2 flashing then,
    1 + 2 = Time out draining Pump connections, blockage, module, circulation pump
    #450200
    mackintyre40
    thanks
    the last few days on drain cycle it was a bit nosiey ill see if any blockages
    thanks peter
