I have a Lamona (HJA8631) dishwasher. Initial start-up is fine. It fills, heats, rinses, then drains, and drains, and drains. The thing tends to go on indefinitely if I didn’t switch it off. It appears ok for the first part of the programme but draws a halt after the first rinse. Should I be looking at a new PCB or what?
Hi. Please first check that the base of the machine is not full of water. (Not the area that you load with plates ect) sounds to me like the main pump has a leak. Normally made by beko. I do have a cheap pump going if its that.
