Dishwasher Diplomat ADP8224
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Dishwasher Diplomat ADP8224
  • #28647
    oliver111
    Can anyone email a list of error codes please? My present problem is error E6. What does this mean, and how do I fix it? A motor whirs for a short while and then it stops.
    #219434
    Re: Dishwasher Diplomat ADP8224
    E6 is no drain detected in the time allowed. Is it actually draining?
    oliver111
    Many thanks Penguin. It transpires that eggshell does not improve the draining! At the moment all is well.
    But I am not sure if the draining pipe which connects with the sink drain is installed correctly, as it is possible that grease from the sink may be backing into the dishwasher pipe.
    #219436
    Make an “up and over” loop in the drain hose – water can only flow uphill with a pump.
    Drain pump is pretty feeble – fine with water, just stops with solids. Remind the Mrs that it’s a dishwasher, not a waste disposal unit. We’ll nurse you through the bruises 😀 .
