dishwasher door seals
Home Forums Public Support Forums Help And Support Dishwasher Help Forum dishwasher door seals
  • #10565
    Following on from the leaking dishwasher saga, any one got any idea how to change a door seal The machine is a bosch and it is the lower front door seal that needs replacing. Can’t find anything obvious or easy way to get at it
    #140651
    Re: dishwasher door seals
    Door outer panel off Malcy will let you see what’s happening. Can’t tell you what the replacement p/no is though, ‘cos you still haven’t posted the model number………………… 😀
    Thanks for that Penguin came off really easy as did the seal was a bit eroded hence the leak, any way after all that my darling wife has decided to buy a new one as she reckons it’ll still leak after I’ve replaced it ( great to be loved and trusted) thanks any way will pop over into a different foeum to check out the best buys thanks
