I have a Bosch Classic Electronic SGS55E42Au/86. The machine fills and then pumps out for a second on overfill. The water in the machine is cold at this stage.
My problem is that I can’t find a sensor that tells the controller that the machine is full and ready to progress through the cycle.I have removed what looks like a temperature sensor (TYP956 5600049491) which has 4 terminals. The first two have continuity and the rest are open circuit measured with a multimeter. I understand that from a previous forum post that this is a temperature sensor as well as a thermistor. I have tried immersing it in boiling water and it does not change state.
Would you mind advising if I am looking in the right direction?
This machine is in Australia
Thanks regards
sparksend
