dishwasher help
  • #65379
    wsbitany
    i was hoping someone could help me with a problem.
    Our dishwasher was working fine until the missus turned the machine off by accident half way through the cycle by the isolator switch above the kitchen work top. Since then I get no live to the on/off switch on the dishwasher door. I do have live from the isolator to the machine but was wondering if the machine has a separate fuse which may have blown, how to access it if this is the case or what else it could be. The dishwasher is a zanussi ZDT 40 built in.
    Many thanks in advance for your time
    wal 😀
    #360290
    Re: dishwasher help
    It may be best to pull the machine out and check the supply point behind the machine. The wall switch is double pole so maybe one pole is at fault here and a new switch required?
